Hi
Egroupware version: 21.1.20210521 Install type: Docker
I have a little problem with a newly installed Egroupware 21.1. Some icons are not display in admin or other modules. In inspector shows permission denied to /pixelegg/images/dhtmxtree Im attached a screenshot.
Can you help with this?
BR Z
I figured out.
In the setup page, i need to set full url without “/” at the end.
Its working properly now.
Thanks.
