Hello everyone,
we have released a new maintenance and Security relaease 26.10.20261030.
Update packages are also available for egroupware-docker and egroupware-guacamole. These should also be installed as part of routine system maintenance.
Release notes:
- SECURITY: one critical security update in EGroupware and one in TinyMCE, everyone is strongly advised to update to this release!
- SAML: repair config.php stuck calling canSetSameSiteNone() statically
- Mail: importing a valid .eml file no longer rejected as “wrong type”
- Mail: notification images embedded via webdav.php still broken on async/cron sends
- Mail: fix CSP-header “502 Bad Gateway” via large allowExternalDomains allowlist
- Mail: 1st page in printed mail only had the headers (serveral different cases fixed)
- Mail: an S/MIME-signed meeting invite was shown as plain text instead of the Accept/Decline/Tentative buttons
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
