Hello everyone,
we have released a new maintenance and Security relaease 26.7.20260710.3
Release notes:
- SECURITY: this release fixes multiple high level security vulnerabilities, everyone is strongly adviced to update to it!
- All apps: inserting a new custom-fields between or before existing ones removes most data from the existing fields
- Calendar/Mail: fix applying an external organizers update did loose the recurrence end-date
- Mail: display title no longer shows “mail-display” prefix
- Mail: fix access check in mail_hooks access method
- Invoices: OCR import now identifies document type (invoice, credit note, …) and billing period
This update is also a security update!
Please be sure to check whether the automatic update worked, or trigger it manually if necessary or desired.
You can find the version here:
https://help.egroupware.org/t/where-can-i-find-the-egroupware-version-number/79853
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
