Hello everyone,
we have released a new maintenance relaease 26.2.20260209.
Release notes:
- Final 26.x release 26.2.20260209
- To update install the new egroupware-docker-26 package Linux package for your distro
- AiTools: target language was not send in prompt to AI (DeepL worked as no prompt)
This is the final version for the release of EGroupware 26.2 on 9 February 2026.
Kind regards
Your EGroupware team
