Egroupware reloading constantly with apcu
I have the latest version 26 installed on shared hosting (I know, I know). I observed the following issue: when I log into the webversion: egroupware constantly reload when using mail app, calendar app, etc, but not when in the administration app. The error log indicated that eT2 template is not found. Also trying to change preferences will result in reloading. This is already going on for years, so I mainly use egroupware so we can share calendar information on mobile phones (CardDav, CalDav).
If I remove the apcu extension, I can access all the apps properly and change preferences etc, but it seems CalDav is depending on the apcu extension.
Does anyone have a moment of brilliance to solve this little issue?
Jaco
Maybe the server logs bring some light into the dark?
