Hello everyone,
we have released a new SECURITY and maintenance relaease 23.1.20260113.
Release notes:
SECURITY and Maintenance Release: strong recommendation to update to this release (or 26.0.20260113) immediately
- Addressbook: Fix renaming distribution list
- Admin/Mail: fix warning about not-a-personal-account was still displayed after changing to a personal one
- Calendar/CalDAV: fix SQL error if event was accepted without changing the status (e.g. accepted twice)
- Filemanager: Fix file a file kept files after uploading them leading to incorrect overwrite prompt
- Search: fix not able to remove search, even if it’s no longer displayed in search-box
Complete changelog:
https://github.com/EGroupware/egroupware/compare/23.1.20260108…23.1.20260113
This time only (security) fixes.
Please make sure that this update is installed!
The version used can be found at: Admin/Admin/Changelog and versions/Changelog
https://help.egroupware.org/t/new-features-preferences-or-other-important-things-since-release-of-egroupware-23-1/77410
in chronological order.
Kind regards
Your EGroupware team
