Hi All,
using the EGW calendar synchronisation with outlook, it occurs that every time the synchronisation takes place, the appointments are duplicated, even though they are exactly on the same date and at the same time and nothing has been changed.
Has anyone encountered the same problem?
Thanks
Gabriele
