I am currently developing a new module for eGroupware as my final year project at University and I have been doing the code corners guidelines. I have managed to implement the first 4 days but for some reason on the fifth day I don’t get the results expected as my edit and delete functionality once I add the nextmatch widget don’t work. By any chance do you have any other example (guidelines) I can follow to use the nextmatch widget as it is used on the day 5 in the code corner?
Thanks and Regards
Alex W.
