Hi, have you configured felamimail at all?
What happens here is, that the Capabilities of your configured IMAP Server
is tested.
If the configured server does not answer the query the foreach loop seems
not to be
an array. You may fix that by either checking the
$ret[âPARSEDâ][âCAPABILITIESâ] for
its qualities as array before looping or turning
$ret[âPARSEDâ][âCAPABILITIESâ] into an array.
But: It is simply a warning and should not cause any other harm.
Best regards
Klaus
âHelmut Halfmannâ halfmann@aept.ruhr-uni-bochum.de schrieb:
Hallo!
Can anybody help me solving the problem concerning this error message:
PHP Warning: Invalid argument supplied for foreach() in
/usr/share/egroupware/egw-pear/Net/IMAPProtocol.php on line 1008,
referer: https://10.0.0.5/home/index.php
The message occours when I open Felamimail. Google was not helpful.
I use Debian SID, eGroupWare Version 1.4.002
Thanx!
Helmut
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Donât miss this yearâs exciting event. Thereâs still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
