The feature to print an email works great but it seems there’s a bug when we try to print from a draft.
Worked fine with versions 23.x.
But since the upgrade on 26, it does not work on Firefox (works on Chromium though).
Egroupware v26.8.20260825 installed via Docker with mariadb and nginx.
Can someone reproduce it?
I would like to now if it’s a bug or an erroneous config.
Well there’s nothing really visual and no error message.
When I select print, a pop-up window of the corresponding mail open. At this point it’s the same behavior on emails and drafts.
But then, only with the drafts, it closes really fast as if I just closed the window and nothing else happens.
We’re currently sorting out an issue with the print function in the ‘Compose’ section of the pre-release version 26.9.20260918.
I’m not sure if this will solve your problem, but the update is due out next week. Let’s see if your problem is still there after that.
