ANMELDUNG MÖGLICH
Aufruf: http://192.168.1.4/egroupware/whoami.php
GET /egroupware/whoami.php HTTP/1.1
Host: 192.168.1.4
Content-Length:
Content-Type:
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3
Accept-Encoding: gzip, deflate
Accept-Language: de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7
Connection: Keep-Alive
Cookie: eGW_cookie_test=enabled; last_loginid=username; last_domain=default
Dnt: 1
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/74.0.3729.158 Safari/537.36 Vivaldi/2.5.1525.43
X-Forwarded-For: 192.168.1.60
X-Forwarded-Host: 192.168.1.4
X-Forwarded-Server: localhost
Remote-Addr: 172.20.0.1
Server-Name: _
Server-Addr: 172.20.0.2
Server-Software: nginx/1.16.1
ANMELDUNG NICHT MÖGLICH
Aufruf: https://meindyndns.ddnss.de/egroupware/whoami.php
Host: meindyndns.ddnss.de
Content-Length:
Content-Type:
Cache-Control: max-age=0
Dnt: 1
X-Forwarded-For: 2aXX:XXXX:XXXX:XXXX:3d8e:a17c:b4c:44d1, 192.168.1.1
X-Forwarded-Host: meindyndns.ddnss.de, meindyndns.ddnss.de
X-Forwarded-Proto: https
X-Forwarded-Server: meindyndns.ddnss.de, localhost
Server-Name: _
Zugriff Groupdav funktioniert:
https://meindyndns.ddnss.de/egroupware/groupdav.php
docker-compose logs -f --tail=10 liefert
> egroupware | EGroupware successful updated
> egroupware | * Starting periodic command scheduler cron
> egroupware | ...done.
> egroupware | [13-Sep-2019 13:54:42] NOTICE: fpm is running, pid 1
> egroupware | [13-Sep-2019 13:54:42] NOTICE: ready to handle connections
> egroupware | [13-Sep-2019 13:54:42] NOTICE: systemd monitor interval set to 10000ms
> egroupware | [13-Sep-2019 14:30:06] NOTICE: [pool www] child 30 exited with code 0 after 2124.424846 seconds from start
> egroupware | [13-Sep-2019 14:30:06] NOTICE: [pool www] child 111 started
> egroupware | [13-Sep-2019 14:47:26] NOTICE: [pool www] child 39 exited with code 0 after 2720.863691 seconds from start
> egroupware | [13-Sep-2019 14:47:26] NOTICE: [pool www] child 168 started
> egroupware-watchtower | time="2019-09-13T13:48:57Z" level=info msg="Waiting for running update to be finished..."
> egroupware-nginx | 2019/09/13 15:13:07 [error] 6#6: *192 FastCGI sent in stderr: "PHP message: PHP Warning: Cookie domains cannot contain any of the following ',; \t\r\n\013\014' in /usr/share/egroupware/api/src/Session.php on line 1636PHP message: #1 /usr/share/egroupware/api/src/Session.php(1636): setcookie('sessionid', 'sd1meh175rique1...', 0, '/', 'meindyndns.ddnss.de...', false, true)PHP message: #2 /usr/share/egroupware/api/src/Session.php(646): EGroupware\Api\Session::egw_setcookie('sessionid', 'sd1meh175rique1...')PHP message: #3 /usr/share/egroupware/login.php(251): EGroupware\Api\Session->create('username@default', 'userpass', 'text', false, true, true, '', NULL)PHP message: #4 {main}PHP message: # Instance=default, User=username, Request=POST http://meindyndns.ddnss.de/egroupware/login.php?phpgw_forward=%252Findex.php%253Fcd%253Dyes, User-agent=Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/74.0.3729.158 Safari/537.36 Vivaldi/2.5.1525.43PHP message: PHP Warning: Cookie domains cannot contain any of the following ',; \t\r\n\013\014' in /usr/share/egroupware/api/src/Session.php on line 1636PHP message: #1 /usr/share/egroupware/api/src/Session.php(1636): setcookie('kp3', 'OA21VG3rmNHyETZ...', 0, '/', 'meindyndns.ddnss.de...', false, true)PHP message: #2 /usr/share/egroupware/api/src/Session.php(647): EGroupware\Api\Session::egw_setcookie('kp3', 'OA21VG3rmNHyETZ...')PHP message: #3 /usr/share/egroupware/login.php(251): EGroupware\Api\Session->create('username@default', 'userpass', 'text', false, true, true, '', NULL)PHP message: #4 {main}PHP message: # Instance=default, User=username, Request=POST http://meindyndns.ddnss.de/egroupware/login.php?phpgw_forward=%252Findex.php%253Fcd%253Dyes, User-agent=Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/74.0.3729.158 Safari/537.36 Vivaldi/2.5.1525.43PHP message: PHP Warning: Cookie domains cannot contain any of the following ',; \t\r\n\013\014' in /usr/share/egroupware/api/src/Session.php on line 1636PHP message: #1 /usr/share/egroupware/api/
