Maybe Alex is using a mixture of trunk and 1.4 …
That’s not going to work, unless you do the conversation of the
phpgw_*.lang files of 1.4 yourself.
Oscar Manuel Gómez Senovilla schrieb:
Ralf Becker escribió:
@omgs: Oscar do you have time to check and fix that?
Aleksander Adamowski schrieb:
Hi!
It seems that french translations have wrong encoding. When I
remove/install apps, I get errors:
Error inserting record: egw_lang values (‘system’,‘icalsrv’,‘fr’,‘Systýme’)
And PostgreSQL logs this:
ERROR: 22021: invalid byte sequence for encoding “UTF8”: 0xe86d65
The encoding on those files is incorrectly ISO-8859-1. This fixes the problem:
recode iso-8859-1…utf-8 < phpgw_fr.lang > phpgw_fr.lang.tmp
mv phpgw_fr.lang.tmp phpgw_fr.lang
If I understand correctly since the file is phpgw_*, that happens in
1.4, where fr is using iso, so I don’t understand the reason why your
system is treating that file as if it was in utf-8. Check that your lang
files and whole installation are properly updated.
Regards.
SF.Net email is sponsored by:
It’s the best place to buy or sell services
for just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Telefon +49 (0)631 31657-0
