Hi !
Is it possible to show more than 5 users at a time in week view ? i know i had to change value in class.calendar_uiviews.inc.php, but in don’t find the good parameters.
Thank you in advance for your answer.
Z.AKSIL.
Hi zaksil.
Hmmmm. I don’t know that there is a limit of 5 anywhere.
Please describe in more detail what you mean and where only 5 users are displayed. Preferably also with screenshots.
Hi StefanU.
In Calendar, i have 7 users to whom I have to keep track of their agendas.
When, i have more than 5 users, i have this vue for a week
But when it’s less than or equal 5 users, i have this vue
zaksil
Does that help?:
Please always check the module-specific (user) settings first when doing such things. Often the solution can be found there.
You can now also post several screenshots in the forum. I have upgraded you.
It’s work ! Thanks you soo much
