Thanks a lot,
but will you take a look in the Groupdav issue as well?
I can switch the behaviour by storing the Accounts ins SQL (works) or
LDAP (broken), the authentication is not relevant here.
I have tracked it down to
class.groupdav_handler.inc.php
function _common_get_put_delete
where entry is filled for SQL but for LDAP in the line
$entry = $this->read($id)
But there I am lost, as I can’t find the function read.
Christoph
Ralf Becker schrieb:
Hi Christoph,
found and fixed.
Christoph Kaulich schrieb:
Thanks, but now I get
[21-May-2008 10:38:31] PHP Fatal error: Class ‘addressbook_csv’ not
found in
/raid/www/htdocs/egroupware/addressbook/inc/class.addressbook_ui.inc.php
on line 507
in my php.log
Christoph
Hi Christoph,
fixed the bug your reported.
It seems to be connected to my db. I just copied my egroupware directory
and set up a plain db with a demo account. There it works fine.
Which tables are connected to the groupdav code, where can I have a look
to change it?
Depends on the application:
- addressbook: egw_addressbook*
- calendar: egw_cal*
- infolog: egw_infolog*
Christoph
PS: While trying to export my address book as csv I got:
CreateObject(‘addressbook.csv_export’): Cant instanciate class!!!
addressbook_ui::action / addressbook_ui::index / call_user_func(Array) /
ExecMethod(addressbook.addressbook_ui.index) / etemplate::process_exec /
call_user_func(Array) / ExecMethod(etemplate.etemplate.process_exec)
Christoph
I only tested with contacts in the db so far. From a conceptional point
of view LDAP should work, but I have not yet tested it.
The groupdav code searched for contact_id if the id given is numeric and
for contact_uid otherwise.
Still looking for differences, do you have your contacts on a LDAP
server or in the database? I have them in the database.
For me it looks like the software is searching in the contact_id field
and not in the contact_uid field for getting the cards.
Christoph
PHP Version 5.2.4, but after updating to 5.2.6 nothing changed.
Christoph
No idea.
What php version do you use?
We sometimes have problems, as I use php5.2.5 and our production
systems are one php5.1.x
It’ s identical to the installation over here.
Is there something in the db I can check?
Christoph
Dipl.-Ing.
Christoph Kaulich Tel.: ++49 (0) 531 / 8 01 12-17
GNS mbH Fax : ++49 (0) 531 / 8 01 12-79
Mobil: ++49 (0) 175 / 2 68 57 05
Am Gaußberg 2 mailto:kaulich@gns-mbh.com
38114 Braunschweig http://www.gns-mbh.com
Sitz und Amtsgericht Braunschweig HRB 4004
Steuernummer 14/203/31601
VAT-Id. DE173536746
Geschäftsführer: Stefan Hanson, Klaus Radtke, Claudius Schöne
