I am having a problem during the upgrade from 20.1.20201028 to 20.1.20201217.
I am using git to fetch the code and no docker. Debian is the OS.
The problem does not seem module specific as it happens during the upgrade process
I do not have any errors in the apache log but I have this in admin page, when the db upgrade runs:
process->pass(): activesync skipped on this pass
process->pass(): bookmarks skipped on this pass
process->pass(): collabora skipped on this pass
process->pass(): news_admin skipped on this pass
process->pass(): openid skipped on this pass
process->pass(): projectmanager skipped on this pass
process->pass(): registration skipped on this pass
process->pass(): tracker skipped on this pass
process->pass(): #19 for upgrade processing
process->upgrade(): Incoming : appname: activesync, version: 20.1, status: U
process->upgrade(): No table upgrade available for appname: activesync, version: 20.1
process->upgrade(): Outgoing : appname: activesync, status: F
process->upgrade(): Incoming : appname: bookmarks, version: 20.1, status: U
process->upgrade(): No table upgrade available for appname: bookmarks, version: 20.1
process->upgrade(): Outgoing : appname: bookmarks, status: F
process->upgrade(): Incoming : appname: collabora, version: 20.1, status: U
process->upgrade(): No table upgrade available for appname: collabora, version: 20.1
process->upgrade(): Outgoing : appname: collabora, status: F
process->upgrade(): Incoming : appname: news_admin, version: 20.1, status: U
process->upgrade(): No table upgrade available for appname: news_admin, version: 20.1
process->upgrade(): Outgoing : appname: news_admin, status: F
process->upgrade(): Incoming : appname: openid, version: 20.1, status: U
process->upgrade(): No table upgrade available for appname: openid, version: 20.1
process->upgrade(): Outgoing : appname: openid, status: F
process->upgrade(): Incoming : appname: projectmanager, version: 20.1, status: U
process->upgrade(): No table upgrade available for appname: projectmanager, version: 20.1
process->upgrade(): Outgoing : appname: projectmanager, status: F
process->upgrade(): Incoming : appname: registration, version: 20.1, status: U
process->upgrade(): No table upgrade available for appname: registration, version: 20.1
process->upgrade(): Outgoing : appname: registration, status: F
process->upgrade(): Incoming : appname: tracker, version: 20.1, status: U
process->upgrade(): No table upgrade available for appname: tracker, version: 20.1
process->upgrade(): Outgoing : appname: tracker, status: F
Setup failure: excess looping in process->pass():
Pass:
Array
Passed:
Array
I am using MySQL
And apache
And php 7.3
I have a few apps that do not show the correct 20.1 version in the admin page even if I force the app upgrade but this is something that has been happening for ages and it has never given any real problems.
For now, when the upgrade fails like that I just roll back to 20.1.20201028 again and restore, which then looks OK
Many thanks for any pointers you may have on this.
