Thanks! Yes… I see… That mail really didn’t make it into my mailbox.
We had some trouble with SPF when moving to the new SMTP-servers…
together with a TTL of 24 hours. Hope that’s over by now.
Right now the “dirty hack” is running well. But I’ll probably have to
get a better way when the next update comes. What’s the .tpl parsed
with? Smarty or a similar template engine?
Regards
Peter
Ralf Becker schrieb:
My answer from 29. Apr. is attached
Peter Guhl schrieb:
Hi Ralf
Well, no offense meant… but I don’t see any answer for “sitemgr:
Making the download-filelist themable”. At the other hand that list
has problems with my mail account since we changed to another MX.
Extreme lag and sometimes “blocked by excessive bouncing” (can’t
track it down, unfortunately, since nobody else complains about
bounces and sends me some of them).
Regards
Peter
Hi Peter,
beside I answered your mail, you can already set the ACL your
require: just use an group directory and set the access in Admin >>
Manage groups by clicking on the ACL icon (pencil) behind the app
name filemanager.
Peter Guhl schrieb:
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don’t miss this year’s exciting event. There’s still time to save
$100. Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Betreff:
Re: [eGroupWare-developers] sitemgr: Making the download-filelist
themable
Von:
Ralf Becker RalfBecker@outdoor-training.de
Datum:
Tue, 29 Apr 2008 23:50:42 +0200
An:
"development of eGroupWare, for active developers"
egroupware-developers@lists.sourceforge.net
An:
Hi Peter,
a tpl file, with the current one in the default dir, is a patch a commit
right away. A php file acting as template not. That can be done equally
well be patching the module (for a single sitemgr instance).
The code you gave for the template path should work, thought SEP is not
really necessary, even windows understands slashes in php nowadays.
Peter Guhl schrieb:
Hello all
I want to have the download-filelist differently. Am I right that,
currently, that is hardcoded in get_content of
class.module_download.php? Then it seems to be time for a patch…
What I am thinking of: Place a small php file containing the part from
line 99 to 104 into the template-path and include it. Of course, that’s
still sort of dirty (would be much more elegant to include a .tpl) but
currently I don’t have the time for more. All I need for that patch is
to know a reliable way to determine the path into the template defined
for the current website. Would the following from sitemgr-site/index.php
do it?
$GLOBALS[‘sitemgr_info’][‘site_dir’] . SEP . ‘templates’
but… well, I am currently a bit lost in the structure… couldn’t say
if that particular information is existing at all in
class.module_download.php…
Regards
Peter
mit freundlichen Grüssen
Peter Guhl
Win-Lux GmbH
Obere Schöntalstrasse 22
CH - 8406 Winterthur
Telefon: +41 (0)81 330 51 51
Mobil +41 (0)76 437 03 09
Fax: +41 (0)81 332 44 58
Mail: peter.guhl@win-lux.ch
Skype: p_guhl
Web: http://www.win-lux.ch
******************* Vertraulichkeitserklärung ***********************
Diese Mitteilung resp. deren Beilagen können vertrauliche und/oder
persönliche Informationen enthalten, die einzig für den adressierten
Empfänger bestimmt sind. Jegliche Kenntnisnahme oder Weiterleitung durch
oder an Dritte ist untersagt. Wenn Sie nicht der adressierte Empfänger sind,
nehmen Sie bitte Kontakt mit dem Absender der Nachricht auf und löschen
Sie alle Kopien. Vielen Dank.
Don’t miss this year’s exciting event. There’s still time to save $100.
