Hola a todos, soy nueva tanto en este foro como con el eGropuWare.
Lo estoy instalando sobre un fedora 12 y un Xampp. Todo va correcto pero a la hora de hacer el test de instalacion me dan muchos warning y un error. Os copio la lista completa. Espero que podais ayudarme, porque ya no se que hacer.
Un beso y gracias de antemano
Passed Checking required PHP version 5.1+ (recommended 5.2+): 5.3.1 ==> True
Passed Checking php.ini: safe_mode = Off: ini_get(‘safe_mode’)=’’ = Off
Passed Checking php.ini: magic_quotes_runtime = Off: ini_get(‘magic_quotes_runtime’)=‘0’ = Off
Passed Checking php.ini: register_globals = Off: ini_get(‘register_globals’)=‘0’ = Off
Passed Checking php.ini: display_errors = Off: ini_get(‘display_errors’)=‘0’ = Off
Passed Checking php.ini: memory_limit >= 24M: ini_get(‘memory_limit’)='64M’
Passed Checking php.ini: max_execution_time >= 30: ini_get(‘max_execution_time’)='90’
Passed Checking php.ini: file_uploads = On: ini_get(‘file_uploads’)=‘1’ = On
Passed Checking php.ini: upload_max_filesize >= 8M: ini_get(‘upload_max_filesize’)=‘64M’
Passed Checking php.ini: post_max_size >= 8M: ini_get(‘post_max_size’)=‘65M’
Passed Checking php.ini: include_path contain .: ini_get(‘include_path’)=’.:/opt/lampp/lib/php’
Warning Checking php.ini: mbstring.func_overload = 7: ini_get(‘mbstring.func_overload’)=‘0’
The mbstring.func_overload = 7 is needed to fully support unicode (utf-8) or other multibyte-charsets.
*** Please make the following change in your php.ini (/opt/lampp/etc): mbstring.func_overload = 7
*** AND reload your webserver, so the above changes take effect !!!
Passed Checking php.ini: magic_quotes_gpc = Off: ini_get(‘magic_quotes_gpc’)=‘0’ = Off
Passed Checking extension session is loaded or loadable: True
Passed Checking extension pdo is loaded or loadable: True
Passed Checking extension mysql is loaded or loadable: True
Passed Checking extension pdo_mysql is loaded or loadable: True
Passed Checking extension pgsql is loaded or loadable: True
Passed Checking extension pdo_pgsql is loaded or loadable: True
Warning Checking extension odbc is loaded or loadable: False
The odbc extension is needed, if you plan to use a MaxDB, MsSQL or Oracle database.
Warning Checking extension pdo_odbc is loaded or loadable: False
The pdo_odbc extension is needed, if you plan to use a MaxDB, MsSQL or Oracle database.
Warning Checking extension oci8 is loaded or loadable: False
The oci extension is needed, if you plan to use a Oracle database.
Warning Checking extension pdo_oci is loaded or loadable: False
The pdo_oci extension is needed, if you plan to use a Oracle database.
Passed Checking extension mbstring is loaded or loadable: True
Passed Checking extension ldap is loaded or loadable: True
Passed Checking extension ctype is loaded or loadable: True
Passed Checking extension imap is loaded or loadable: True
Passed Checking extension dom is loaded or loadable: True
Passed Checking extension gd is loaded or loadable: True
Passed Checking PEAR is installed: 1.9.0
Warning Checking PEAR::HTTP_WebDAV_Server is installed: False
PEAR::HTTP_WebDAV_Server is needed by: WebDAV. You can install it by running: pear install HTTP_WebDAV_Server
Passed Checking PEAR::Auth_SASL is installed: 1.0.2
Warning Checking PEAR::Net_IMAP is installed: False
PEAR::Net_IMAP is needed by: EMailAdmin, felamimail. You can install it by running: pear install Net_IMAP
Passed Checking PEAR::Net_Sieve is installed: 1.1.1
Warning Checking PEAR::XML_Feed_Parser is installed: False
PEAR::XML_Feed_Parser is needed by: news_admin. You can install it by running: pear install XML_Feed_Parser
Passed Checking PEAR::Log is installed: 1.8.7
Passed Checking file-permissions of /opt/lampp/htdocs/egroupware for not world writable: root/root drwxr-xr-x
This might take a while, please wait …
Error Checking if php.ini setting session.save_path=’’ is writable by the webserver: root/root drwxr-xr-x
/opt/lampp/htdocs/egroupware/setup is not writable by the webserver !!!
You will NOT be able to log into eGroupWare using PHP sessions: “session could not be verified” !!!
Passed Checking function imagecreatefromjpeg exists: True
