I try using syncml with blackberry 8100. It says Synchronization failed. Open tunnel - failure.
I use funambol 3.0.8
I have the APN configuration in blank it’s ok?
I read the manual and i do the changes but anywhere says about APN
Hi.
No, with the blackberry apn is not possible (until they allow this ports to pass in their proxies), you must use your telephony provider apn
It’s free the use of the apn for my provider?
I don’t know each provider may vary, in mine a data plan contract is needed to use at affordable cost
