I was using syncevolution to sync via SyncML my evolution calendar to
egroupware, and so my wife.
Suddenly syncevolution sto working, with error 20007, and seems not a
cure apart try egw SyncML 1.2 version, look at:
http://bugzilla.moblin.org/show_bug.cgi?id=5631
So i’m considering switching to caldav, supported by evoluton too.
But i was not able to use more then one calendar, eg i can use an URI
like:
caldav://my.server/groupdav.php/calendar/
auth as my user ‘gaio’, but i cannot use an url like:
caldav://my.server/groupdav.php/anna/calendar/
if i try to auth as my user gaio (that have full read access to anna’s
calendar by ACL) i got only a repeated password prompt.
if i try to auth as user anna, i got in log:
[Sun Dec 27 16:17:49 2009] [error] [client 192.168.4.20] An error happened: Wrong domain! '' != 'default'
[Sun Dec 27 16:17:49 2009] [error] [client 192.168.4.20] #0 /usr/local/share/egroupware/phpgwapi/inc/class.egw.inc.php(269): egw_session->verify()
[Sun Dec 27 16:17:49 2009] [error] [client 192.168.4.20] #1 /usr/local/share/egroupware/phpgwapi/inc/class.egw.inc.php(217): egw->verify_session()
[Sun Dec 27 16:17:49 2009] [error] [client 192.168.4.20] #2 /usr/local/share/egroupware/phpgwapi/inc/functions.inc.php(83): egw->wakeup2()
[Sun Dec 27 16:17:49 2009] [error] [client 192.168.4.20] #3 /etc/egroupware/header.inc.php(113): require_once('/usr/local/shar...')
[Sun Dec 27 16:17:49 2009] [error] [client 192.168.4.20] #4 /usr/local/share/egroupware/groupdav.php(49): include('/etc/egroupware...')
[Sun Dec 27 16:17:49 2009] [error] [client 192.168.4.20] #5 {main}
I’ve also tried tu use the url with ?domain=default appended, as found
in:
http://old.nabble.com/Problem-with-the-groupdav-calendar-sync-td24901248s3741.html
with the same result.
How can i use more then one calendar to the same server?
many thanks.
Il diavolo fa i file system ma non i tool di ripristino.
(Claudio Piciarelli)
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon’s best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
