When I use a normal account with DMS access to search for files, or open folders with very large (several thousand) documents, the session runs out of memory, tells me:
Fatal error: Allowed memory size of 524288000 bytes exhausted (tried to allocate 7680 bytes) in /var/www/egroupware/phpgwapi/inc/class.egw_db.inc.php(1962) : runtime-created function on line 1
and maybe spits out documents (Maybe all the documents, maybe just some. It’s hard to tell)
However, when I give the group for that user admin power, the problem goes away.
If I increase the PHP memory limit, the memory usage simply increases until I restart apache2 or the server simply freezes.
Right now, we have most users running with admin powers, which is unacceptable in the long run. Any ideas? Need more info?
Info: Egroupware 1.6
Ubuntu 8.04
PHP:
memory_limit = 500M ; Maximum amount of memory a script may consume (32MB)
