Hello everybody,
Changelog 21.1.20220408
- All: fix regression causing older browsers (Firefox < 69 and Safari < 14.1) to display EGroupware
- Filemanager/SMB: fix not working sharing of SMB shares (with fixed credentials!)
This Maintanace update is provided via Docker container.
Only two bugfixes for the last EGroupware Maintenance Release 21.1.20220406.
No new functions or settings.
in chronological order.
Many greetings
Your EGroupware team
