Hello everybody,
Changelog 21.1.20220916
- Mail/RichTextEditor: common preference “small paragraph” now changes return key to a line break instead of a paragraph (with margin)
- Mail: remove left (and right) margin of p and div, which can interact bad with the signature
- Mail/Calendar: fix applying a participant reply as organizer overwrote event with data send by the participant (not just his status)
- Mail/SAML/SSO: show mail accounts requiring the session password as Error, but load the other accounts
- OpenID Connect: autodiscovery support via /.well-known/openid-configuration
- LDAP/AD/OpenID Connect: fix error creating tokens with profile claim, if user has a picture
- EPL/CTI/Placetel: set CSP to fix not playing voice-mail
This Maintenance update is provided via Docker container and packet.
The installation package makes a correction in the reverse proxy configuration for the OpenID autodiscover.
Please be careful during installation => Never without backup
in chronological order.
Many greetings
Your EGroupware team
