Hello everyone,
we have released a new maintenance relaease 26.4.20260429.
Release notes:
- Admin: fix not opening items in context menu e.g. to edit mail account of a user
- Mail: fix double opening of mails through double-click or enter
- Api: file-upload shows now different progressbar when processing the file (reassembling the file-chunks)
- Calendar: fix wrong timezone in recurrences, if server-timezone is different from event TZ
- kDots/OpenIDConnect: fix not working setting to allow microphone or clipboard access e.g. for OpenWebUI
- AiTools: make model, reasoning effort, temperature and timeout configurable in general and for each prompt
It is now possible to configure the model, reasoning effort, temperature and time limit both generally and for each individual prompt.
Promt:
General:
Kind regards
Your EGroupware team
