Hello everyone,
we have released a new maintenance relaease 26.9.20260907.
Release notes:
- Addressbook: fix international address style
- Addressbook: state/territory selection for Australian addresses
- Api: fix history now showing anything
- Calendar: fix 6 month event purge was not taking 6 months
- Mail: fix import-message upload not submitting
- Mail: fix uncaught exception crashing send/save-as-draft when a server-side referenced attachment’s source message is gone
This time only fixes!
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
