Hello there, I installed the mydms module, and installed it correctly, I’m able to create directories, but when I try to upload a document I get the following errors:
Adding document “Atencion.pps” to folder “Root-Folder”…
Warning: opendir(/var/lib/egroupware/default/files/mydms/) [function.opendir]: failed to open dir: No such file or directory in /homepages/20/d198301198/htdocs/egroupware/mydms/inc/inc.FileUtils.php on line 97
Warning: readdir(): supplied argument is not a valid Directory resource in /homepages/20/d198301198/htdocs/egroupware/mydms/inc/inc.FileUtils.php on line 98
Warning: mkdir(/var/lib/egroupware/default/files/mydms/00000/) [function.mkdir]: No such file or directory in /homepages/20/d198301198/htdocs/egroupware/mydms/inc/inc.FileUtils.php on line 32
An error has occured
Can someone be kind enough and help me solve this issue, Thank You
