If a try svn update * i get the same error message as previously
what to try else ?
thanks,
sp
[/quote]
Ok I going on slowly.
I mv the existing egroupware to egroupware1.4
Afterwards svn checkout of development version
Moved the header.inc.php from egroupware1.4 to the new egroupware directory
Ran setup, and performed an ugrade.
It was just claiming about missing apps (gallery, icalsrv, mydms, notifywindow)
I checkout the 3 first one and deleted the last one
So everything is ok now.
But I was expecting that the new version should correct a problem I have.
When you forward or reply to a mail with an attachment and save it as an infolog, the infolog does’nt has a link to the attachment !
many thanks for the assistance,
sp
