Hello Nathan,
I try a lot of thing… But no success…
Please confirm, among the things tried were the instructions I
provided, exactly, yes or no.
If the instructions provided do not work, please indicate the step
where the results deviate from the expected.
So just for your information I think I found something wrong…
When I create a client, I use the phone number of the client like
5555551111.
But I think the pERP auto assign a number in the database different
of the
selected ID from the user.
This is correct. Humans use all kinds of weird references. pERP
uses an auto incrementing integer internally.
Your number is stored as the client number, and is for human
reference only.
So a customer “client_id” in the database should be 1,2,3,etc. but not
number 5555551111 .
This is correct, however client_id != client_num != user_id
client_id: {1,2,3,…}
client_num: {5555551111, 0012, 1002, AB701C}
user_id: {-2, 3, 5}
This does not change the fact that you need a custom field in the
project manager named client_id.
Start with 1 project.
You have the needed custom field, client_id, set for that project.
In Admin->Accounts Receivable->Site Configuration, the following is
at the bottom:
You need both checkboxes selected. The PM check enables invoicing
PM. The category checks allow those particular categories to be
invoiced, and No category allows Projects with No category to be
invoiced.
When you create an invoice, you must set the client first.
If all of the above is correct, and it still doesn’t work, try:
- Create another category in ProjectManager
- Assign a project to that category
- Enable invoicing of that category in AR
- Try and invoice again
- Let me know if that works
Nathan Gray
nathan at goarctic dot com
Nathan Gray
SF.Net email is sponsored by: The Future of Linux Business White Paper
from Novell. From the desktop to the data center, Linux is going
mainstream. Let it simplify your IT future.
http://altfarm.mediaplex.com/ad/ck/8857-50307-18918-4
Perp-developers mailing list
Perp-developers@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/perp-developers
