Just use webdrive or netdrive, windows alone has a lot issues with
non-ascii chars.
nothingg schrieb:
I think that there is no solution. Only i can put webdav files and folder if
i do a copy paste in windows. But not directly using excel or word.
Also, If i haven an accent (not space) it appears in webdav a space like %20
, if didnt have accent the space its ok.
Example:
DIRECTORY OF MY HOME
DIRECTÓRY%20OF%20MY%20HOME
specher wrote:
nothingg wrote:
I have the same problem, no solution there
specher wrote:
Hello,
We are using egw 1.6. I am doing some tests with webdav.
The problems I have are :
- When there is a “special character” like a space or accent in a file
name of a file stored in the filemanager, I can’t access it with webdav
(got errors, or the file is appearing 2 times …)
- When I create a new document with word or excel and try to save it to
a webserver link (like
http://mydomain/egroupware/filemanager/webdav/home/…) I get an error
"there has been a network or file permission error". In egw I can see
that the file is created but with 0 byte. If I try to save it a second
time, i get a message file already exist, overwrite ? -> yes and then
the file saves without problem.
I saw that there where modifications done in trunk regarding webdav. Is
it worth to update to the svn version ? Are there risks, because this is
my production system. Is it possible to only uograde the
filemanager/webdav application, if yes how to do it ?
thanks,
sp
Still no solution ?. I really would like to have webdav working.
thanks
sp
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Nigel Vickers und Ralf Becker
Register Now & Save for Velocity, the Web Performance & Operations
Conference from O’Reilly Media. Velocity features a full day of
expert-led, hands-on workshops and two days of sessions from industry
leaders in dedicated Performance & Operations tracks. Use code vel09scf
and Save an extra 15% before 5/3. http://p.sf.net/sfu/velocityconf
