Hallo und guten Abend,
eine Installation macht Ärger, Mails können weder empfangennoch versendet werden:
Hat jemand eine Idee, ist da die Datenbank beschädigt?
Gruss
Uwe
postfix: Postfix is using backwards-compatible default settings
postfix: See http://www.postfix.org/COMPATIBILITY_README.html for details
postfix: To disable backwards compatibility use "postconf compatibility_level=3.6" and "postfix reload"
Jun 16 19:55:52 egroupware postfix[1]: Postfix is using backwards-compatible default settings
Jun 16 19:55:52 egroupware postfix[1]: See http://www.postfix.org/COMPATIBILITY_README.html for details
Jun 16 19:55:52 egroupware postfix[1]: To disable backwards compatibility use "postconf
/usr/sbin/postconf: warning: /etc/postfix/main.cf: support for parameter "smtpd_tls_dh1024_param_file" will be
removed; instead, do not specify (leave at default)
postfix/postlog: starting the Postfix mail system
Jun 16 19:55:58 egroupware postfix/master[1]: daemon started -- version 3.9.4, configuration /etc/postfix
Jun 16 19:58:19 egroupware postfix/smtpd[75]: warning: unsupported dictionary type: lmdb. Is the postfix-lmdb
package installed?
Jun 16 19:58:19 egroupware postfix/smtpd[75]: error: unsupported dictionary type: lmdb
Jun 16 19:58:19 egroupware postfix/smtpd[75]: connect from egroupware.fritz.box[192.168.178.43]
Jun 16 20:03:07 egroupware postfix/smtpd[79]: warning: unsupported dictionary type: lmdb. Is the postfix-lmdb
package installed?
Jun 16 20:03:07 egroupware postfix/smtpd[79]: error: unsupported dictionary type: lmdb
Jun 16 20:03:07 egroupware postfix/smtpd[79]: connect from unknown[192.168.178.4]
Jun 16 20:03:08 egroupware postfix/trivial-rewrite[81]: warning: mysql:/etc/postfix/sql-aliases.cf: query failed:
Illegal mix of collations for operation 'UNION'
Jun 16 20:03:08 egroupware postfix/trivial-rewrite[81]: warning: virtual_alias_domains: mysql:/etc/postfix/sql-
aliases.cf: table lookup problem
Jun 16 20:03:08 egroupware postfix/trivial-rewrite[81]: warning: virtual_alias_domains lookup failure
Jun 16 20:03:08 egroupware postfix/smtpd[79]: warning: mysql:/etc/postfix/sql-aliases.cf: query failed: Illegal
Jun 16 20:03:08 egroupware postfix/smtpd[79]: warning: mysql:/etc/postfix/sql-aliases.cf lookup error for
"info@xxxxxxxxx.de"
Jun 16 20:03:08 egroupware postfix/smtpd[79]: NOQUEUE: reject: RCPT from unknown[192.168.178.4]: 451
4.3.0 <info@mpundp.de>: Temporary lookup failure; from=<root@pve.xxxxxxxx.de> to=<info@xxxxxxx.de>
proto=ESMTP helo=<pve.xxxxxx.de>
Jun 16 20:03:08 egroupware postfix/smtpd[79]: disconnect from unknown[192.168.178.4] ehlo=1 mail=1
rcpt=0/1 data=0/1 rset=1 quit=1 commands=4/6
Jun 16 20:03:19 egroupware postfix/smtpd[75]: timeout after CONNECT from
Jun 16 20:03:19 egroupware postfix/smtpd[75]: disconnect from egroupware.fritz.box[192.168.178.43]
commands=0/0
