I have the same problem.
I did delete the file and re-created. Same issue.
I am using Fecora Core 6.
Ralf Becker wrote:
I guess something is messed up in your header.inc.php. Either look
at it
and fix it, or delete it and start again.
deeztech schrieb:
I’m stuck in an endless loop trying to install the applications
during
egroupware initial installation. Once I login with the config
admin, I
click the button to install the applications, it immediately
takes me
back
to the login screen to login as config admin or header admin
login. I
login
as config admin, and the button to install the applications is still
there.
It’s not installing and I’m stuck in the endless loop.
Help would be greatly appreciated.
P.S. I created the egroupware database manually.
Using Tomcat but need to do more? Need to support web services,
security?
Get stuff done quickly with pre-integrated technology to make your
job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache
Geronimo
http://sel.as-us.falkag.net/sel?
cmd=lnk&kid=120709&bid=263057&dat=121642
View this message in context: http://www.nabble.com/Problems-
installing-applications-tf2460397s3741.html#a7330344
Sent from the egroupware-users mailing list archive at Nabble.com.
Message: 2
Date: Tue, 14 Nov 2006 05:42:01 GMT
Subject: Re: [eGroupWare-users] egroupware installation problem in
linux
To: discussions and questions of users for users of eGroupWare
egroupware-users@lists.sourceforge.net
Message-ID: 200611140542.kAE5g01t027376@um1.unlimitedmail.net
Thanks a lot for showing me the right way. I have gone through
your article. You have suggested to create a vhost.conf file.
Where should I create that file. please note I am using
Plesk-7.5.4. my vhost path is /var/www/vhosts/ and under the
vhosts I have different domains. I think I am very near to the
solution but still I need some more help about file locations
etc. As a newbie I request you to
you are using Plesk and Plesk sets open_basedir in each vhost
configuration and NOT via the php.ini.
Have a look in our Knowledgebase, there’s an article I wrote
some time
ago about how to setup eGW in Plesk.
j.bakshi@unlimitedmail.org schrieb:
Your situation getting better
Create a /var/lib/php5 directory, which is writable by your
webserver.
well :-=) I do have a /var/lib/php5 from the very begining. I
mentioned this in my very first mail. and yes after modifying
the php.ini I have restarted the apache2 as you suggested.
eGroupWare using php session handling features and php must
store sessions (as
far as I know).
In this case, php must save the temporary session files.
The directory mentioned in your error log is the right place.
After eliminate this session problem, we will back to pear.
By the way, did you restart/reload your webserver?
There is an option in the Setup: check php or similar. You
can check the
open_basedir there.
István
j.bakshi@unlimitedmail.org írta:
check your open_basedir variable in php.ini and after you
append the path to
pear, just reload apache.
And check that, apache is able to run pear or not.
Thanks for your response. I have tried your suggestion by
including “/usr/share/php5:/usr/share/php5/PEAR” at
open_basedir of php.ini. But still have the same problem
of not
finding pear. more over there is an error like
Checking if php.ini setting session.save_path=’/var/lib/php5’
is writable by the webserver:
/var/lib/php5 does not exist !!!
You will NOT be able to log into eGroupWare using PHP
sessions:
“session could not be verified” !!!
Please help me to solve the problem.
István
Hi all,
I am a newbie in egroupware. I have suse 9.3 with appache2
server and apache-mod_PHP5 module. during installation
egroupware reports that there is no PEAR installed but I DO
HAVE pear in my system. More over it reports
/var/lib/php5 is
not there and again I have /var/lib/php5. So could one
kindly
suggest me how to solve it ?
thanks
services, security?
make
your job easier
Apache Geronimo
Message sent from the
Unlimited Mail Free Services Platform.
http://www.unlimitedmail.net
services, security?
make your job easier
Apache Geronimo
services, security?
your job easier
Apache Geronimo
services, security?
Apache Geronimo
services, security?
your job easier
Apache Geronimo
Message: 3
Date: Tue, 14 Nov 2006 08:31:54 +0100
Subject: Re: [eGroupWare-users] phpcollab with egroupware
Message-ID: 455970EA.8080303@digitalrock.de
Content-Type: text/plain; charset=ISO-8859-1
I have no interest to add an other project management application
(which
is not integrated at all) to eGW. My interest is to improve / develop
ProjectManager, which is fully integrated with eGW.
edgeworx schrieb:
You are not alone in your wants. I would also love to see phpcollab
integrated into egroupware much like Gallery was ported to work.
Ralph, any thoughts?
I found this on php-collab’s forums:
http://www.php-collab.org/community/index.php?
t=msg&goto=7552&S=e1f04561ed5cf23398b0bd86f659faaf&srch=egroupware#ms
g_7552
Indraveni wrote:
I am not satisfied with the Project Manager in eGroupware. So I
decided
to
include the PhpCollab Project Management Tool
(http://php-collab.org) into eGroupware.
Any body there who have done this previously.
I added this as a simple application into eGRoupware. But there
shd be
single login. How can i continue??
Any Ideas??
This SF.net email is sponsored by: Splunk Inc. Do you grep
through log
files
searching your log files as easy as surfing the web. DOWNLOAD
SPLUNK!
http://sel.as-us.falkag.net/sel?cmd=lnk&kid3432&bid#0486&dat1642
Message: 4
Date: Tue, 14 Nov 2006 08:36:00 +0100
Subject: Re: [eGroupWare-users] Inviting a group of person => Private
status in calendar
Message-ID: 455971E0.3080905@digitalrock.de
I can NOT verify the behaviour you described. Group invitations are
not
private, unless you check the private checkbox.
ProjectDriver’s Team schrieb:
I have a question concerning the calendar.
When I’m Scheduling a meeting for a group, the event appear with
a private
status in each member’s calendar.
Is it normal ?
Is there a solution to keep the “public” status ?
Thanks,
Projectdriver’s Team
Message: 5
Date: Mon, 13 Nov 2006 23:46:24 -0800 (PST)
Subject: [eGroupWare-users] LDAP - can create but can’t authenticate;
To: egroupware-users@lists.sourceforge.net
Message-ID: 7332868.post@talk.nabble.com
Content-Type: text/plain; charset=us-ascii
Hi!
There is LDAP running on localhost together with eGroupWare:
@(#) $OpenLDAP: slapd 2.3.19 (Feb 13 2006 11:19:24) $
root@ls20-bc1-14.build.redhat.com:/usr/src/build/708086-i386/BUILD/
openldap-2.3.19/openldap-2.3.19/build-servers/servers/slapd
eGroupWare is configured to use certain place in LDAP tree.
I can create new account with eGroupWare into LDAP.
There is LDAP log output of creating account:
Nov 14 08:36:18 manitou slapd[2006]: conn=30 fd=14 ACCEPT from
IP=127.0.0.1:55930 (IP=0.0.0.0:389)
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=0 BIND
dn=“cn=Manager,o=oiwuw,c=pl” method=128
dn=“cn=Manager,o=oiwuw,c=pl” mech=SIMPLE ssf=0
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=0 RESULT tag=97
err=0 text=
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=1 SRCH
base=“ou=grupy,ou=egw-prezent,o=oiwuw,c=pl” scope=2 deref=0
filter="(&(cn=default)(phpgwAccountType=g))“
Nov 14 08:36:18 manitou slapd[2006]: <= bdb_equality_candidates:
(phpgwAccountType) index_param failed (18)
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=1 SEARCH RESULT
tag=101
err=0 nentries=1 text=
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=2 SRCH
filter=”(&(cn=admins)(phpgwAccountType=g))“
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=2 SEARCH RESULT
tag=101
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=3 SRCH
filter=”(&(cn=admin_example)(phpgwAccountType=g))“
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=3 SEARCH RESULT
tag=101
err=0 nentries=0 text=
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=4 SRCH
base=“ou=konta,ou=egw-prezent,o=oiwuw,c=pl” scope=2 deref=0
filter=”(&(uid=admin_example)(phpgwAccountType=u))“
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=4 SEARCH RESULT
tag=101
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=5 SRCH
filter=”(uidNumber=7)“
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=5 SEARCH RESULT
tag=101
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=6 SRCH
filter=”(&(uidNumber=7)(phpgwAccountType=u))“
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=6 SEARCH RESULT
tag=101
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=7 SRCH
filter=”(uid=admin_example)"
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=7 SEARCH RESULT
tag=101
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=8 ADD
dn=“uid=admin_example,ou=konta,ou=egw-prezent,o=oiwuw,c=pl"
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=8 RESULT tag=105
err=0 text=
Nov 14 08:36:18 manitou slapd[2006]: conn=30 op=9 UNBIND
Nov 14 08:36:18 manitou slapd[2006]: conn=30 fd=14 closed
Nov 14 08:36:18 manitou slapd[2006]: conn=31 fd=14 ACCEPT from
IP=127.0.0.1:55932 (IP=0.0.0.0:389)
Nov 14 08:36:18 manitou slapd[2006]: conn=31 op=0 BIND
Nov 14 08:36:18 manitou slapd[2006]: conn=31 op=0 RESULT tag=97
err=0 text=
Nov 14 08:36:18 manitou slapd[2006]: conn=31 op=1 SRCH
filter=”(&(uidNumber=*)(phpgwAccountType=u))"
Nov 14 08:36:18 manitou slapd[2006]: conn=31 op=1 SEARCH RESULT
tag=101
err=0 nentries=7 text=
Nov 14 08:36:18 manitou slapd[2006]: conn=31 op=2 UNBIND
Nov 14 08:36:18 manitou slapd[2006]: conn=31 fd=14 closed
Nov 14 08:38:08 manitou slapd[3191]: @(#) $OpenLDAP: slapd 2.3.19
(Feb 13
2006 11:19:24) $
Nov 14 08:38:08 manitou slapd[3191]: daemon: bind(8) failed errno=98
(Address already in use)
Nov 14 08:38:08 manitou slapd[3191]: slapd stopped.
Nov 14 08:38:08 manitou slapd[3191]: connections_destroy: nothing to
destroy.
After this I can see new account using slapcat:
dn: uid=admin_example,ou=konta,ou=egw-prezent,o=oiwuw,c=pl
userPassword:: e21kNX1JU012S1hwWHBhZERpVW9PU29BZnd3PT0=
phpgwAccountType: u
phpgwAccountExpires: -1
homeDirectory: /home/admin_example
loginShell: /bin/false
cn: admin admin
sn: admin
givenName: admin
uid: admin_example
uidNumber: 7
gidNumber: 2
objectClass: top
objectClass: person
objectClass: organizationalPerson
objectClass: inetOrgPerson
objectClass: posixAccount
objectClass: shadowAccount
objectClass: phpgwAccount
phpgwAccountStatus: A
structuralObjectClass: inetOrgPerson
entryUUID: 8f6e350a-07fe-102b-96ba-9f78aaabd4b3
creatorsName: cn=Manager,o=oiwuw,c=pl
createTimestamp: 20061114073618Z
entryCSN: 20061114073618Z#000000#00#000000
modifiersName: cn=Manager,o=oiwuw,c=pl
modifyTimestamp: 20061114073618Z
Unfortunately authorisation using any account doesn’t procced.
Here is LDAP detailed log while trying to get access to eGW:
Nov 14 08:44:00 manitou slapd[2006]: conn=39 fd=14 ACCEPT from
IP=127.0.0.1:33181 (IP=0.0.0.0:389)
Nov 14 08:44:00 manitou slapd[2006]: conn=39 op=0 BIND
Nov 14 08:44:00 manitou slapd[2006]: conn=39 op=0 RESULT tag=97
err=0 text=
Nov 14 08:44:00 manitou slapd[2006]: conn=39 op=1 SRCH
filter="(&(cn=admin_example)(phpgwAccountType=g))“
Nov 14 08:44:00 manitou slapd[2006]: conn=39 op=1 SEARCH RESULT
tag=101
Nov 14 08:44:00 manitou slapd[2006]: conn=39 op=2 SRCH
Nov 14 08:44:00 manitou slapd[2006]: <= bdb_equality_candidates:
(*) Nov 14 08:44:00 manitou slapd[2006]: conn=39 op=2 SEARCH RESULT
tag=101
Nov 14 08:44:00 manitou slapd[2006]: conn=40 fd=25 ACCEPT from
IP=127.0.0.1:33182 (IP=0.0.0.0:389)
Nov 14 08:44:00 manitou slapd[2006]: conn=40 op=0 BIND
Nov 14 08:44:00 manitou slapd[2006]: conn=40 op=0 RESULT tag=97
err=0 text=
Nov 14 08:44:00 manitou slapd[2006]: conn=40 op=1 SRCH
filter=”(&(uid=admin_example)(phpgwAccountStatus=A))“
Nov 14 08:44:00 manitou slapd[2006]: conn=40 op=1 SRCH attr=uid dn
givenName
sn mail uidNumber gidNumber
(phpgwAccountStatus) index_param failed (18)
Nov 14 08:44:00 manitou slapd[2006]: conn=40 op=1 SEARCH RESULT
tag=101
Nov 14 08:44:00 manitou slapd[2006]: conn=40 op=2 BIND anonymous
mech=implicit ssf=0
dn=“uid=admin_example,ou=konta,ou=egw-prezent,o=oiwuw,c=pl” method=128
Nov 14 08:44:00 manitou slapd[2006]: conn=40 op=2 RESULT tag=97
err=49 text=
Nov 14 08:44:00 manitou slapd[2006]: conn=40 op=3 UNBIND
Nov 14 08:44:00 manitou slapd[2006]: conn=40 fd=25 closed
Nov 14 08:44:00 manitou slapd[2006]: conn=39 op=3 UNBIND
Nov 14 08:44:00 manitou slapd[2006]: conn=39 fd=14 closed
Nov 14 08:44:00 manitou slapd[2006]: conn=41 fd=14 ACCEPT from
IP=127.0.0.1:33184 (IP=0.0.0.0:389)
Nov 14 08:44:00 manitou slapd[2006]: conn=41 op=0 BIND
Nov 14 08:44:00 manitou slapd[2006]: conn=41 op=0 RESULT tag=97
err=0 text=
Nov 14 08:44:00 manitou slapd[2006]: conn=42 fd=25 ACCEPT from
IP=127.0.0.1:33185 (IP=0.0.0.0:389)
Nov 14 08:44:00 manitou slapd[2006]: conn=42 op=0 BIND
Nov 14 08:44:00 manitou slapd[2006]: conn=42 op=0 RESULT tag=97
err=0 text=
Nov 14 08:44:00 manitou slapd[2006]: conn=42 op=1 SRCH
filter=”(&(cn=admin_3)(phpgwAccountType=g))“
Nov 14 08:44:00 manitou slapd[2006]: conn=42 op=1 SEARCH RESULT
tag=101
Nov 14 08:44:00 manitou slapd[2006]: conn=42 op=2 SRCH
filter=”(&(uid=admin_3)(phpgwAccountType=u))"
Nov 14 08:44:00 manitou slapd[2006]: conn=42 op=2 SEARCH RESULT
tag=101
Nov 14 08:44:00 manitou slapd[2006]: conn=42 op=3 UNBIND
Nov 14 08:44:00 manitou slapd[2006]: conn=42 fd=25 closed
Nov 14 08:44:00 manitou slapd[2006]: conn=41 op=1 UNBIND
Nov 14 08:44:00 manitou slapd[2006]: conn=41 fd=14 closed
Please notice line marked with (*) - there is one result of searching
account context.
Still it doesn’t authenticate (“Bad login or password” appears).
Wha’s wrong?
TIA
AdamLis;
View this message in context: http://www.nabble.com/LDAP---can-
create-but-can%27t-authenticate–tf2627822s3741.html#a7332868
security?
job easier
Geronimo
End of eGroupWare-users Digest, Vol 7, Issue 49
Dhr. R.R. Gerbrands
