gholm schrieb:
This is a follow-on post from
http://www.nabble.com/egroupware-1.6001-%2B-Synthesis-Syncml-%3D-error-403-td23870413s3741.html
this and is serious enough to warrant a separate post.
I’m running eGW 1.6001 on Centos 5.2. On July 2, I applied the latest
http://k.noc.de/index.php?option=com_content&view=article&id=6&Itemid=8
SyncML patch , and tried to sync my Palm using Synthesis client. It didn’t
work, but the next day I noticed the patch had updated, so I uninstalled the
older, and installed the newer one. (using the instructions on that page)
My next sync attempt was a partial success (phone client need to be set to
sync at SyncML 1.2 protocol). It synced calendar but not all of my contacts.
On each sync attempt, the phone client logged 2100 out of 2800 contacts had
errors and therefore refused to update my phone, and for the remaining 700
contacts it’d duplicate them into my phone, and then back into eGW on next
sync etc etc ad infinitum … grrr. duplicates aaaah.
Anyway, this is where the main problem arose.
I have set eGW to autobackup each night. So in order to clear those
duplicates etc, I decided to restore an older backup. It was corrupt!
Nothing appeared upon restore, all data gone. and I had no admin panel to
continue restoring.
I had to drop the mysql table and start from scratch to get it working, the
whole eGW install process incl header.inc.php file needed to be done again.
Each backup was corrupt until I reached the 1st July, the night before I’d
first done my SyncML patch work. Interestingly the size of the 1st July
backup was 1.7 meg, and the next day onwards they were 1.4mb, so I could see
SOMETHING was awry
Nothing else happened on my system at that time except the SyncML patching,
so I believe
the SyncML patch install/uninstall/update process either allowed corruption
of the database or tampered with eGW backup procedure and prevented proper
backup.
We just started testing with the patch, so I cant say much about it.
I know the backup process and I doubt the patch can temper with it. More
likely you lost what’s missing in the backup with your initial sync and
did not recognise it at that time.
I should mention that throughout the whole period of time, the live database
was fine. It was only the backed-up and then restored databases that were
corrupt.
This is a rather serious problem since no one is likely to discover it until
they try to restore their data from backup.
Can someone shed some light?
The backup is a collection of csv files, have you looked into it?
As it is line based, you should be able to use diff two (unpacked) files.
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Nigel Vickers und Ralf Becker
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World™ will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize
details at: http://p.sf.net/sfu/Challenge
