Since EGroupware version 21.1.20210923 it is possible to run the community version of EGroupware on a Univention Corporate Server (UCS) of our partner Univention.
For this you have to:
and run EGroupware as a community version.
The uninstallation also removes the data (tables) of the EPL applications. Configurations are retained.
The function for uninstalling the EPL functions is also available in installations that are not installed on UCS.
To reinstall the EPL functions, add the applications again via the setup. Call up the setup under
https://IP/egroupware/setup/
and reinstall the EPL functions:
And in a second run:
Of course, we still recommend using our EPL version
The EPL functions include:
- Kanban-Board
- CTI-Integration
- Rules/automation GDPR-compliant handling of address data
- File versioning and deletion protection, folder/file subscription
- Additional file sharing security, extended file sharing options
- Encryption of InfoLog descriptions
- Upgrade-safe adaptation of the EGroupware masks
- Many other useful additional functions
The additional functions and applications are particularly useful for business users.
Further information:
In addition, we offer discounted and preferential Support via our support portal (and by telephone German/English), training and individual application development.
Licences for Collabora Online as an ideal complement to EGroupware can also be obtained directly from EGroupware:
We have set up a category for EGroupware on UCS in our forum:
Questions specifically about the operation of EGroupware on a UCS should be posted there.
For topics concerning UCS itself, the Univention forum is available:
Kind regards
Your EGroupware Team
