ok… I found why the error I described above occurred
I had the php var for override enabled, so any code in .htaccess was overriding the php.ini
I was happy in discovering that (since I’m a noob) but I’m facing now another error… :s
"HTTP server error: 500. Server failure."
Here is now the debug :
22:54:08 GMT +0:00 [DEBUG] - Writing configuration settings to the management tree
22:54:09 GMT +0:00 [DEBUG] - [UI] StartSync begin
22:54:09 GMT +0:00 [DEBUG] - [UI] Hide menu
22:54:09 GMT +0:00 [DEBUG] - [UI] Starting the syncThread…
22:54:09 GMT +0:00 [DEBUG] - A new version (0) is available
22:54:09 GMT +0:00 [DEBUG] - newVersion=0
22:54:09 GMT +0:00 [DEBUG] - version=8.5.4
22:54:09 GMT +0:00 [DEBUG] - The available version is not an upgrade, ignore it
22:54:09 GMT +0:00 [DEBUG] - Starting the Sync process…
22:54:09 GMT +0:00 [DEBUG] - Set a lower priority to the process
22:54:09 GMT +0:00 [DEBUG] - Set listeners
22:54:09 GMT +0:00 [DEBUG] - Creating SyncSources…
22:54:09 GMT +0:00 [DEBUG] - Creating the sync-mutex (“fol-SyncInProgress-1278366849”)
22:54:09 GMT +0:00 [DEBUG] - Start SyncClient::Sync() with 1 sources
22:54:09 GMT +0:00 [INFO] -
************************** BEGIN of Synchronization session **************************
22:54:09 GMT +0:00 [DEBUG] - Synchronization URL: http://(IP)/egroupware/rpc.php
22:54:09 GMT +0:00 [INFO] - Preparing synchronization of contact…
22:54:09 GMT +0:00 [DEBUG] - Checking devinfo…
22:54:09 GMT +0:00 [DEBUG] - devinfo hash: B9PWDMg5G4ppR7bZ+UOsYA==
22:54:09 GMT +0:00 [DEBUG] - devinfo changed, retransmit
22:54:09 GMT +0:00 [DEBUG] - Server capabilities are invalid (Server URL changed)
22:54:09 GMT +0:00 [DEBUG] - Initialization message:
22:54:09 GMT +0:00 [DEBUG] - User Agent = Funambol Outlook Sync Client v. 8.5.4
22:54:09 GMT +0:00 [DEBUG] - Initialization sent.
22:54:09 GMT +0:00 [DEBUG] - <?xml version="1.0" encoding="UTF-8"?>
22:54:09 GMT +0:00 [DEBUG] - Connecting to (IP):80
22:54:09 GMT +0:00 [DEBUG] - Requesting resource /egroupware/rpc.php
22:54:09 GMT +0:00 [DEBUG] - Sending data of size 4512…
22:54:09 GMT +0:00 [DEBUG] - Message sent
22:54:09 GMT +0:00 [DEBUG] - Finished sending data of size 4512.
22:54:09 GMT +0:00 [DEBUG] - HTTP server error: 500. Server failure.
22:54:09 GMT +0:00 [DEBUG] - Error occurred in sync: code 3 = HTTP server error: 500. Server failure.
22:54:09 GMT +0:00 [ERROR] - Error in preparing sync: HTTP server error: 500. Server failure.
================ SYNCHRONIZATION REPORT ================
SYNCHRONIZATION COMPLETED WITH ERRORS
Last error message = "HTTP server error: 500. Server failure."
Last error code = 2052
Contacts:
Not synced.
22:54:09 GMT +0:00 [DEBUG] - Saving configuration to winRegistry
22:54:09 GMT +0:00 [DEBUG] - Writing configuration settings to the management tree
22:54:09 GMT +0:00 [DEBUG] - saving dataStores…
22:54:09 GMT +0:00 [DEBUG] - dataStores saved
22:54:09 GMT +0:00 [DEBUG] - Releasing sync-mutex…
22:54:09 GMT +0:00 [DEBUG] - Sync-mutex released - closing handle.
22:54:09 GMT +0:00 [DEBUG] - Delete SyncSources…
22:54:09 GMT +0:00 [INFO] - Syncronization process completed with errors (code = 2052).
22:54:09 GMT +0:00 [DEBUG] - Current time is: 1278366849
22:54:09 GMT +0:00 [DEBUG] - Next check time is: 86400
22:54:09 GMT +0:00 [INFO] - Check on server location for update
22:54:09 GMT +0:00 [DEBUG] - Update url: http://(IP):80/sapi/profile/client?action=get-update-info&component=outlook&version=8.5.4&format=properties
22:54:09 GMT +0:00 [DEBUG] - Requesting resource /sapi/profile/client?action=get-update-info&component=outlook&version=8.5.4&format=properties
22:54:09 GMT +0:00 [DEBUG] - HTTP request error: resource not found (status 404)
22:54:09 GMT +0:00 [ERROR] - No response from update server
22:54:09 GMT +0:00 [ERROR] - Client update error - uses the stored parameters
22:54:09 GMT +0:00 [DEBUG] - Saving Updater configuration
22:54:09 GMT +0:00 [ERROR] - update check failed
22:58:58 GMT +0:00 [DEBUG] - Current Timezone = (UTC) Dublin, Edimburgo, Lisboa, Londres
22:58:58 GMT +0:00 [DEBUG] - Reading configuration settings from the management tree
22:58:58 GMT +0:00 [DEBUG] - Server DeviceConfig not found, create a default one.
23:04:14 GMT +0:00 [DEBUG] - [UI] StartSync begin
23:04:14 GMT +0:00 [DEBUG] - [UI] Hide menu
23:04:14 GMT +0:00 [DEBUG] - [UI] Starting the syncThread…
23:04:14 GMT +0:00 [DEBUG] - A new version (0) is available
23:04:14 GMT +0:00 [DEBUG] - newVersion=0
23:04:14 GMT +0:00 [DEBUG] - version=8.5.4
23:04:14 GMT +0:00 [DEBUG] - The available version is not an upgrade, ignore it
23:04:14 GMT +0:00 [DEBUG] - Starting the Sync process…
23:04:14 GMT +0:00 [DEBUG] - Set a lower priority to the process
23:04:14 GMT +0:00 [DEBUG] - Set listeners
23:04:14 GMT +0:00 [DEBUG] - Creating SyncSources…
23:04:14 GMT +0:00 [DEBUG] - Creating the sync-mutex (“fol-SyncInProgress-1278367454”)
23:04:14 GMT +0:00 [DEBUG] - Start SyncClient::Sync() with 1 sources
23:04:14 GMT +0:00 [INFO] -
Any Ideas ?
