Hello everybody,
Changelog 23.1.20230824
- Api: Store recoverable password (encrypted) for shares so you don’t have to change it when you forget
- Mail: new modus for vacation notice to not save message to INBOX and REST API to set vacation handling
- Mail: Add attachment action “Forward to” that adds file directly to compose window
- Mail/ActiveSync: fix wrong mime-type / broken mail when AS smart-forward is used e.g. by gmail app
- Calendar/CalDAV: Thunderbird and CalDAVSynchronizer: update only participant data, instead of failing when the event was changed
- Calendar/CalDAV: do NOT limit number of returned events for GET requests with download parameter
- Calendar/CalDAV: download of whole calendar as ics with a GET request on the collection and download GET parameter gave an empty file
- Calendar: Change how participant emails are shown
- PostgreSQL/Mail: fix SQL error querying email avatars
- smallPART: automatic subscribe everyone (including teachers) only as student on LTI launch, course owner must grant higher rights
- Status: add rocketchat group preference in order to be able to show selective RC groups in status app
- Tracker: Add ability to set due date through mailhandling and escalations
- Tracker: Add configuration option to set ticket start date from email
- AD/LDAP: added a DN filter to the periodic import to e.g. use 2 OU with a shared base
- AD/LDAP: fix periodic incremental import was loosing memberships to local groups for modified users
- AD/LDAP: fix duplicate key account_lid error on import caused by mixed case in account-names not treated equal
- AD/LDAP: fix local uploaded pictures are lost when automatic import is used
- ActiveDirectory: fix not working ldaps connection on a non-standard port
- General: Add new translations and icons
It is now possible to set in the absence note that the answered e-mail is not saved in the inbox.
It is also possible to set that no out-of-office message is sent. In this way, you can also only set a forwarding with the out-of-office message.
Furthermore, we have created an API for out-of-office notification:
This means that the out-of-office notification can also be controlled by other systems such as holiday planners.
It is now possible to attach attachments from e-mails directly to a new e-mail:
It is now possible to select Rocket.Chat groups for display in the status sidebar.
in chronological order.
Many greetings
Your EGroupware team
