Hello everybody,
Changelog 23.1.20230620
- Mail: Add new pane option for showing all columns in vertical 3-pane view
- Mail: fix mixed up inline images and attachments in smime signed messages
- Calendar: fix external organizer was not notified by mail (and other missing notifications of non-users)
- Calendar: Fix clicking a day in a different month in sidemenu jumped to wrong date
- Calendar: Deleting an event sometimes left other user’s alarms
- Calendar: Adding alarms sometimes gave incorrect “can’t add alarms in the past” error
- Calendar: History tab showed start / end times in server time, not user time
- Home: Fix birthdays were not visible
- Infolog / Tracker: Change timesheet total columns to ignore timesheet ACL
- Infolog: History tab showed start / due / completed dates in server time, not user time
- Timesheet: When changing duration, update quantity if it’s not been set to something different
- Api: Fix custom etemplates were still used after deletion
- eSync: fix meeting requests confirmed via ActiveSync protocol got wrong time
- EPL: fixed/completed Wildix PBX implementation
- full list of changes https://github.com/EGroupware/egroupware/compare/23.1.20230524...23.1.20230620
- All apps: Improve icons and translations
It is now possible to select the 3-column view with all columns and configure the column as usual.
We have expanded the implementation of Wildix Cloud Telephone Systems.
No CTI yet? Check out our CTI integration page:
We recommend (especially for Germany) our partner Placetel.
For/with Placetel we have the best integration and functionality.
More about CTI: Contact
in chronological order.
Many greetings
Your EGroupware team
