Hello everyone,
we have released a new maintenance relaease 23.1.20260131.
Release notes:
- probably last 23.1 maintenance release, final 26.x release planned for Februar 9th
- Addressbook: fixed after security release not working advanced search
- Calendar: Fix reordering resources removed them from list of selected calendars
- some more minor fixes, see changelog
Complete changelog:
https://github.com/EGroupware/egroupware/compare/23.1.20260113…23.1.20260131
We plan to release the new EGroupware version 26.x on 9 February 2026.
We will publish further information at that time.
The update will not be distributed automatically(!), but will be offered as a package update and must therefore be installed/initiated manually.
This means that everyone can and must decide for themselves when the update makes sense in their environment.
https://help.egroupware.org/t/new-features-preferences-or-other-important-things-since-release-of-egroupware-23-1/77410
in chronological order.
Kind regards
Your EGroupware team
