Deutsch siehe unten
In 2020, web browser vendors will stop supporting TLS 1.0 and TLS 1.1.
This means, If EGroupware is not encrypted with TLS >= 1.2, you will not be able to call EGroupware with the then current web browsers.
Other web applications are of course also affected.
So there is now a need for action to avoid being surprised by a browser update one day.
Here are a few contributions:
We have published an article on SSL encryption:
It also contains information about the TLS versions and how to configure them.
From the beginning of 2020, websites that still offer TLS 1.0 and TLS 1.1 will also be downgraded:
Our customers in hosting do not have to do anything. SSL is and will continue to be optimally configured in the future.
When deactivating TLS 1.0 and TLS 1.1, it can happen that end devices/clients do not work anymore because they do not support TLS > 1.1.
Likewise, enabling TLS 1.3 can cause problems for clients/devices if TLS 1.3 is not supported correctly.
So the configuration changes should be done step by step and always with a backup of the configuration.
Once again we would like to draw your attention to the supported PHP versions. There are still some EGroupware installations running with PHP versions that are no longer supported.
https://www.php.net/supported-versions.php
We offer technical support, update and upgrade support and hosting migration offers:
For questions a short mail to info@egroupware.org is sufficient.
Many greetings
Your EGroupware Team
In 2020 werden die Webbrowser-Hersteller die Unterstützung von TLS 1.0 und TLS 1.1 einstellen.
Das bedeutet:
Sollte EGroupware nicht mit TLS >= 1.2 verschlüsselt sein, wird man EGroupware mit den dann aktuellen Web-Browsern nicht mehr aufrufen können.
Andere Web-Anwendungen sind natürlich ebenso betroffen.
Es besteht also jetzt Handlungsbedarf, um nicht eines Tages von einem Browser-Update überrascht zu werden.
Hier ein paar Beiträge dazu:
Zur SSL-Verschlüsselung haben wir einen Beitrag veröffentlicht:
Darin auch Hinweise auf die TLS-Versionen und wie man diese konfiguriert.
Ab Anfang 2020 werden auch Webseiten, die noch TLS 1.0 und TLS 1.1 anbieten, herabgestuft:
Unsere Kunden im Hosting müssen nichts unternehmen. SSL ist und wird auch in Zukunft optimal konfiguriert sein.
Bei der Deaktivierung von TLS 1.0 und TLS 1.1 kann es vorkommen, dass Endgeräte/Clients nicht mehr funktionieren weil diese kein TLS > 1.1 unterstützen.
Ebenso kann das Einschalten von TLS 1.3 dazu führen, dass Endgeräte/Clients Probleme bekommen wenn TLS 1.3 nicht korrekt unterstützt wird.
Die Konfigurationsänderungen sollten also Schritt für Schritt und immer mit einer Sicherung der Konfiguration vorgenommen werden.
Noch einmal möchten wir auf auf die unterstützten PHP-Versionen hinweisen. Es werden immer noch einige EGroupware-Installation mit nicht mehr unterstützten PHP-Versionen betrieben.
Wir bieten technische Unterstützung, Update- und Upgrade-Unterstützung und Umstiegsangebote in das Hosting an:
Für (An-)Fragen reicht eine kurze Mail an info@egroupware.org
Viele Grüße
Euer EGroupware Team
