1 / 3
Feb 2021
Dear All,
we are using EGw with jitsi hosted on KiwiTalk
with our own domain.
Today on an updated system (Powered by EGroupware 20.1.20210125 EPL), I noticed that the internal async Calendar notifications include the wrong link. They link to the public jitsi server meet.jit.si and not our own:
The emails sent to externals and also the links copied from the caledar entry include the correct link https://own.domain
Can you confirm this?
Thank you in advance and best regards,
Alex
  • created
    Feb '21
  • last reply
    Feb '21
  • 2
  • 811
  • 2
  • 3
    links
Hi Alex.
When did you register the KiwiTalk server?
Does that change after
Clear cache and register hooks
I have also noticed this case on an installation (my private one) after a change of the Jitsi server.
Hello Stefan,
thanks for your hint, it showed me the right direction. Clear cache and register hooks did not directly solve the problem, but after I deleted all temp files from the server directory and tried again the problem was solved :grinning:
Now the the link is correct.
Thanks again!
Alex
