1.2rc3
Folks
Is anyone else encountering problems with the various 1.2RC versions
and Firefox 1.5Beta? I am having a whole bunch of issues. As far as
I can tell, none of them occur when I log in to the egroupware.org
demo site, so it is probably something local. All of the problems
are specific to Firefox 1.5, everything works fine on Firefox 1.07
and IE 6.0.
Problem 1
On my local setup after a CVS update all appears to be good except
when I go into specific calendar entries (edit or view). When I do
this I can only see info on the General tab. All of the other tabs
just show blank ‘pages’
Problem 2
For projectManager items I have a similar problem except the only tab
I can view is Description. All of the other tabs are blank.
My error log does show the occasional pair of error messages
PGMERR Programmer failed to pass FILE and/or LINE in next
log message*
/export/home/apache/html/egroupware/phpgwapi/inc/class.error.inc.php
93
Permissions
Attempted to access 'notifywindow’
0
This is running egw on an Fedora FC4 box, with PHP5.
Thanks for any input.
Peter
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
