I just reinstalled egw 1.2RC8 and contrib then did a cvs update.
I am running
Debian sarge,
apache2
php5
mysql
When first going to calendar view i see an error message and all time slots
are labelled as 09:00.
Error is:
Warning: Division by zero in
/var/www/egroupware/calendar/inc/class.uiviews.inc.php on line 601
times show 9.00 for all slots!
On looking at the code it appears that the default granularity is not set on
install.
If I edit preferences and set a granularity time of eg60 then the error
disappears. If I reset granularity=default then the error reappears.
when you first login to calendar it checks for reasonable default prefs
and sets eg. the interval to 30min. Only if you reset it to “no default”
(=0) you get this error, during the same session.
I changed it now in cvs, that the check is done on each page request.
systematic schrieb:
I am running
Debian sarge,
apache2
php5
mysql
Error is:
install.
http://sel.as-us.falkag.net/sel?cmd=k&kid0944&bid$1720&dat1642
