Hiya,
I’m submitting icalsrv.php patched, in order to allow HTTP autentication.
As we treated before
(http://www.nabble.com/Bug-in-icalsrv.php(-)-tf2416562s3741.html)
The problem with icalsrv was the session handler.
I hope you can test it and report any problem that you have.
Regards, Paco
Aquel que planta árboles bajo los
que sabe muy bien que nunca se
sentara, ha descubierto el auténtico
significado de la vida.
