Authentication via MAIL problems
Hi there!
I’m using eGroupWare version 1.2.101
I’m having some problems trying to set the eGroupware authentication
type to MAIL.
I set it to MAIL, but cannot login.
I can login using SQL auth., and havenŽt tried with LDAP yet.
Are there any known problems about this?
Is there anything important I should know?
Thanks in advance!
Mario Gomide
Hello!
Without any error messages there is nothing we can help with.
Lars Kneschke
Metaways Infosystems GmbH
Pickhuben 4
20457 Hamburg
Germany
eGroupWare Training & Support ==> http://www.egroupware-support.net
Web: http://www.metaways.de
Tel: +49 (0)40 317031-21
Fax: +49 (0)40 317031-81
Mobile: +49 (0)175 9304324
you problem might be, the mail-auth class tries to use tls. You should be
able to see that in your mail logs.
Try the patched file, I attach to this mail and let me know if it works for
you. You need to save it at phpgwapi/inc/class.auth_mail.inc.php
Hi there!
type to MAIL.
I can login using SQL auth., and haven?t tried with LDAP yet.
Thanks in advance!
Mario Gomide
Outdoor Unlimited Training GmbH
Leibnizstr. 17
67663 Kaiserslautern
