Ticket modified by Tracking System at 2011/01/18 16:05
Tracking System: Bugs
Category: API
Version: Version 1.8.001
Status: Closed
Resolution: Rejected
Completed: 80%
Priority: 5 - medium
Created By: Peter Tuhársky
Created on: 2009/07/21 14:53
Assigned to: Ralf Becker
Summary: #2175 - Editation window usually too small for most apps
The editation window is generally small for most apps (Tracker, InfoLog, Calendar) and user must enlarge or scroll it in order to get to all buttons and fields. The small size is unnecessarry, even on 15"LCD (1024x768) the full scale window fits in seamlessly.
Comment by Tracking System at 2011/01/18 16:05:
Comment by Birgit Becker at 2011/01/04 16:05:
Hi Peter,
the most applications use now popups instead of showing the information in a full browser-window. I can NOT confirm that the most application-popups are to small. Sometimes if User-Names for example are to long, the template can have a weird look, but it’s nothing general.
Birgit
Comment by Peter Tuhársky at 2010/12/21 13:47:
For certain machines, application opens a new tab in browser. For some however, new window is opened. I don’t know, how this behaviour could be affected.
Comment by Tracking System at 2010/12/17 18:02:
Comment by Ralf Becker at 2010/12/03 17:49:
Dear EGroupware user,
Thanks for your understanding
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2175&no_popup=1
