Bugs #2249: syncml not working with nokia e71
Ticket modified by Jörg Lehrke at 2010/09/25 11:14
Tracking System: Bugs
Category: SyncML
Version: Version 1.6.003
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: nils nils
Assigned to: Jörg Lehrke
Summary: #2249 - syncml not working with nokia e71
Please see attached error logfile, I followed the instructions at http://www.egroupware.org/index.php?page_name=wiki&wikipage=SyncMLMobilePhone and got those errors.
Another possible issue:
[Mon Sep 14 15:41:17 2009] [error] [client 192.168.2.110] You need to set mbstring.func_overload to 0 for rpc.php.
During the setup routine, egroupware checks for this variable and tells me to set it to 7 (not 0) in /etc/php5/apache2/php.ini … something’s wrong there, not sure if it’s related to this error.
Comment by Jörg Lehrke at 2009/09/14 22:44:
If eGW dies during the upload from your E71, you have to increase the memory even more.
Comment by Jörg Lehrke at 2009/09/14 22:43:
Sure you can remove your private data. You could also try to limit the amount of data records sent within one package. Set MaxEntries to a small value > 0 to begin with (e.g. 1). Maybe this helps.
Comment by nils nils at 2009/09/14 22:29:
Hi Jörg,
yes, I already tried that, it times out on the E71 end, and segfaults again on the EGW end doing jsut the addressbook… I’m a bit hesitant to post the log because the names and phone numbers are in there… can I just filter out the VCARD lines and send it?
Cheers, Nils
Comment by Jörg Lehrke at 2009/09/14 21:56:
Could you please try to separate the different datastores to multiple sessions?
You are now synchronizing contacts, tasks and calendar at once and it is difficult to find out what causes the problem. The 64M-log doe not show any irregularities to me; it just stops.
Comment by nils nils at 2009/09/14 21:37:
Hi Jörg,
ok, done, memory is 64M, segfaults are gone, but still the errors (see file attachment). Let me know what else I can do.
Thanks, Nils
Comment by Jörg Lehrke at 2009/09/14 21:26:
There are processes dying in your installation with SIGSEG (11). I have no idea what went wrong at your side. Maybe you should increase the memory for PHP.
Comment by nils nils at 2009/09/14 16:02:
using SyncML 1.2 instead of version 1.1 gives this error:
[Mon Sep 14 16:00:15 2009] [error] [client 192.168.2.110] EGWSYNC: [] SyncML: No DTD found for /4609 [on line 62 of "/usr/share/egroupware/phpgwapi/inc/horde/Horde/RPC/syncml_wbxml.php"]
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2249&no_popup=1
