Bugs #2461: fresh install branch 1.6.002 rev. 29005 crash
Ticket modified by Tracking System at 2010/12/17 18:02
Tracking System: Bugs
Category: Setup
Version: Version 1.6 (unsupported)
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: David DVORAK
Assigned to: Ralf Becker
Summary: #2461 - fresh install branch 1.6.002 rev. 29005 crash
Fresh install egw from svn (branch 1.6.002 rev. 29002) crash in step create new admin account.
message :
ldap_add(,cn=Default,ou=groups,o=default,dc=zsvalcika,dc=eu,Array ( [objectclass] => Array ( [0] => mozillaabpersonalpha [1] => evolutionperson [2] => top [3] => posixgroup ) [gidnumber] => 1001 [cn] => Default ) ) Object class violationldap_add(,cn=Admins,ou=groups,o=default,dc=zsvalcika,dc=eu,Array ( [objectclass] => Array ( [0] => mozillaabpersonalpha [1] => evolutionperson [2] => top [3] => posixgroup ) [gidnumber] => 1002 [cn] => Admins ) ) Object class violation
BUT fresh install stable ver. 1.6.002 (build 2009-07-20) is O.K.
In both case is config PC the same :
Ubuntu Karmic_64, LDAP with rfc2307bis.schema, Mysql, Apache
Comment by Tracking System at 2010/12/17 18:02:
Comment by Ralf Becker at 2010/12/03 17:48:
Dear EGroupware user,
Thanks for your understanding
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2461&no_popup=1
