Ticket modified by Tracking System at 2010/12/17 18:02
Tracking System: Bugs
Category: ImportExport
Version: Version 1.6 (unsupported)
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: ron bareis
Assigned to: not assigned
Summary: #2597 - Call to undefined method uidefinitions::read()
ERROR Call to undefined method uidefinitions::read() in …\class.uidefinitions.inc.php on line 137
when you try to run import/export from admin application
Latest snapshot has the same error.
Comment by Tracking System at 2010/12/17 18:02:
Comment by Ralf Becker at 2010/12/03 17:48:
Dear EGroupware user,
Thanks for your understanding
Comment by ron bareis at 2010/05/14 11:09:
Ok, bit more investigation … is this actually a functioning app? The templates directory is really sparce! Did someone get a girlfriend and lose interest in this app
Comment by ron bareis at 2010/05/14 10:20:
actually, it was bodefinitions::read() that was not found … my stuffing around to explore the problem led to the uidefinitions::read() error.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2597&no_popup=1
