Bugs #2642: connection errors withy syncml and nokia e52
Ticket modified by Jörg Lehrke at 2010/09/25 11:09
Tracking System: Bugs
Category: SyncML
Version: Version 1.6.003
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: Peter Brille
Assigned to: Jörg Lehrke
Summary: #2642 - connection errors withy syncml and nokia e52
In Version 1.6.002 there was no problem whith synching my nokia e52 via syncml.
Since Version 1.6.003 I get “Verbindungsfehler” (english: Connection error) when trying to do a sync. The egw-user actually has permission to use syncml.
This is what a apache-log looks like when trying to sync:
“POST /egw/rpc.php HTTP/1.1” 200 409 “-” “S60 SyncML HTTP Client”
Also look at this german thread:
http://egroupware.219119.n3.nabble.com/Nach-Upgrade-auf-1-6-003-syncml-Probleme-mit-nokia-tp841985p841985.html;cid=1275741621822-121
Comment by Jörg Lehrke at 2010/06/07 12:41:
Hi Peter, could you please delete the existing device history for your e52 (underneath the SyncML preferences) and sync again. Be aware that this will force a slow sync of this device and may therefore generate duplicates. You can also enforce a synchronization direction (e.g. enforce the server content to reload the device).
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2642&no_popup=1
