Ticket modified by Pavel Alexeev at 2011/04/01 00:35
Tracking System: Bugs
Category: Wiki
Version: Version 1.8.001
Status: Open
Resolution: None
Completed: 0%
Priority: 5 - medium
Created By: Pavel Alexeev
Created on: 2011/03/26 14:03
Assigned to: Ralf Becker
Summary: #2913 - Incorrect URL parsing in wiki
For example phrase:
“Future request is a queue of [http://x-www.info/egroupware/index.php?menuaction=tracker.tracker_ui.index tracker] intended for suggestions of new futures.”
Turned to:
“Future request is a queue of www.info/egroupware/index.php?menuaction=tracker.tracker_ui.index” target="_blank">tracker intended for suggestions of new futures."
where part “www.info/egroupware/index.php?menuaction=tracker.tracker_ui.index” is link on “http://x-www.info/egroupware/etemplate/process_exec.php?menuaction=wiki.wiki_ui.edit”
But must be:
"Future request is a queue of tracker intended for suggestions of new futures."
where “tracker” is link to "http://x-www.info/egroupware/index.php?menuaction=tracker.tracker_ui.index tracker"
Comment by Pavel Alexeev at 2011/04/01 00:35:
Sorry, but what wrong with my URL? It is correct and fully real.
Furthermore, I’ve tried quote it in few manner but without success.
Comment by Birgit Becker at 2011/03/31 17:24:
Its caused by the “x-www” this seems to be interpreted wrongly, if you use the same URL without the x- it works fine.
I’m not sure, if this is something we want to fix, but i talk to Ralf about that
Birgit
Comment by Pavel Alexeev at 2011/03/26 14:05:
Shit.
There text also was garbled by unusual way (meantime I understand why - even WYSISYG editor does not used. I’ll fill another bug on it).
I’ve attach file with plain text copied from that editor before “save” button was pressed. Please see it to proper understand problem and compare results.
linked entries:
http://www.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=2913&no_popup=1
