Ticket modified by Klaus Leithoff at 2011/09/19 09:39
Tracking SystemBugs
CategoryFelamiMail
VersionTrunk
StatusOpen
ResolutionNone
Completed20%
Priority5 - medium
Created byStefan Roder
Created on2011/09/13 22:52
Assigned toKlaus Leithoff, Ralf Becker
Summary#3038 - strange behavior since r36575
Hello Klaus,
don’t know if this belongs to felamimail, but I’ve got at least two errors since updating to r36575.
First, the automatic completion of names in the “To” field of felamimail stopped working. No matter which name I write down, there is the whole userslist shown in a scrolldownmenu, alphabetically sorted, but ending up after the first 68 ! entries (which makes no sense at all - why 68 and not 25 or 50 maybe?).
Second, me and my users get an “undefined” error message generated by the notifications modul.
Screenshot attached.
Regards
Comment by Klaus Leithoff at 2011/09/19 09:39:
Did you update json.php as well?
As described error behavior of that ticket, seems to be solved as far as I am concerned.
You describe something quite differently, may be connected anyhow, but I cannot reproduce that behavior.
Please try to delete cache and cookies, as cached stuff may influence behavior.
Sometimes - if you use stuff like APC with your site, changes in code are not affecting the websites delivered to the client. If so, you may have to clean this cache too.
Comment by balazs zeller at 2011/09/18 16:34:
after update I have still the same issue: messages not showed in the folders, tested with chrame and firefox. Revert back to 36583 filemimail works fine again.
Thanks,
Balazs
Comment by Stefan Roder at 2011/09/16 18:49:
Hi Klaus,
Hi Ralf,
it works again thanks to your fix.
Have a nice weekend,
Comment by Klaus Leithoff at 2011/09/16 15:38:
No, but I post your error_log Messages, and include Ralf to the ticket.
> > Hier die entsprechende Meldung im apache-errorlog:
> > [Tue Sep 13 22:52:23 2011] [error] [client 85.177.232.33] PHP Warning:
> Missing
> > argument 1 for notifications_ajax::confirm_message() in
> > /srv/www/htdocs/notifications/inc/class.notifications_ajax.inc.php on
> > line 134, referer:
> > http://myhost/index.php?menuaction=felamimail.uifelamimail.viewMainS
> > creen&ajax=true
> > [Tue Sep 13 22:52:27 2011] [error] [client 85.177.232.33] PHP Warning:
> > json_decode() expects parameter 1 to be string, array given in
> > /srv/www/htdocs/phpgwapi/inc/class.egw_json.inc.php on line 42, referer:
> > http://myhost/admin/index.php
Comment by Stefan Roder at 2011/09/15 23:47:
Any effort on this? The changes Ralf made today (and missing .xet file) had no effect. I had to stop notification for now because reverting back did not work.
Greetings
Comment by Klaus Leithoff at 2011/09/14 17:15:
Jupp, Ralf changed something within egw json libraries.
He/We will have a look tomorrow.
Please revert back for the time.
Comment by balazs zeller at 2011/09/14 14:25:
rev 36584 brakes again filemimail: messages and preview not showed, etc…
thanks,
Balazs
Comment by Klaus Leithoff at 2011/09/14 09:31:
As you statet in a personal Mail: mail address completion issue was solved with update of json.php.
undefined: had that one once. but could not track it down, or reproduce it.
If you can, please check with egw_notificationpopup before acknowledging the popup.
Maybe you can get a clue, how I may be able to reproduce the problem encountered.
Linked entries:
https://community.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=3038&no_popup=1
