Duplicate entries in KDE kontact
I use suse 10.0, KDE 3.5, Egw 1.2.004
Teorethicaly synchronisation between Kontact and EGW is ok, but:
  1. Entries somehow duplicates in KDE Calender. It is impossible to
    delete these events form KDE (they appere after reload), after
    deleting it from EGW it does not dissapear in Kontact
  2. After editing entries in Kontact it goes out of synch with eGW.
    Atfer that it is unable to delete them.
  3. Egw does not retrieve status of tasks form kontact. All kontact
    tasks in egw is marked like “?”
Maybe simple solutions are awailable to fix these problems? Any
comments
I see a lot of this sort of thing and hear about it from my user base. I
keep pointing them to the kde developers so that they can get the client
straightened out. I would suggest the same to you.
We had a kde developer in house for a bit (different part of kde than the
calendar) and he supplied some fixes for part of the problem (but this was a
few releases ago so they no longer patch correctly). He also stated that
much of the xmlrpc client code needs work. This is why I push such request
from users to the egw lists to post directly to the kde developers/lists.
Good luck,
erics
comments
easier
Eric D. Schabell M.Sc - http://www.schabell.com
Any ideas how to solve this problems?
Con it be caching problem in Kalender?
Thats interesting, it looks like only to people has problems whit Kontact.
maybe Kontact users should united to puch little bit harder KDe develoters to fix these bugs…
